Sun Jul 10, 2016 1:48 am
Resolved the issue of link color — sample at this post:—
MWP 7 (ßeta) | Windows 10 Pro (2004) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
Sun Jul 10, 2016 1:54 am
rusticdog wrote:
QuietOne wrote:Two other problems, or differences, I've already noted:
(1) The "New Post" Icon does absolutely NOTHING unlike the old one did. The old one took you to the Oldest Unread post but this one just sits there and looks stupid! (i.e. Dumb!) It would be much better if it acted in the same manner as the old one did.
(2) Even when the user clicks on the Thread Title, it doesn't take the user to the oldest unread post (which the old forum s/w didn't do either, but ...), so the user ends up having to scroll all the way through the thread to find the last stuff htey hadn't yet read. :facepalm :facepalm :rant :help Alternatively, if #1 is fixed then this one (#2) is fine.
It's not very clear right now, but in your screenshot you'll see the arrow pointing right, that's the new post link. Definitely needs improvement.
Have also noticed a difference in behavior between the Main Forum Page Forum Icons and the Thread Icons on the Beta testing Forum (see SC's).
MAIN FORUM PAGE:
BETA FORUM PAGE:
15" MacBook Pro, OS X 10.10.5, 16GB RAM, w/ Parallels 11.x running Win7 SP1 Ultimate, Mozilla Thunderbird. All T'bird accnts: POP3. iPhone Mail Accounts IMAP. Unsubscrbd DNSBL.
Sun Jul 10, 2016 1:57 am
QuietOne wrote:
You mean a darker text such as the following:— :devil
Yes, Darker is BETTER (and NOT Just Bolded) but also get away from JUST GRAY (in color)! (i.e. Gray on White background) :facepalm :facepalm
Sun Jul 10, 2016 2:04 am
TrustFire wrote:Divided the Board post and signature with a subtle touch:—
Would also help to divide the Post "Text Body" from the "Quoted Text" and also from the "Signature" as well. (i.e. Such as using a Horizontal Rule or something else of that nature etc.)
Re: [Bugs + Suggestions]: "The NEW Board Upgrade
Sun Jul 10, 2016 2:06 am
QuietOne wrote:Please don't design things that rely ONLY on a touchscreen as some of us don't have them and REQUIRE mice! :devil
I hang out in the IPB community and these Developers are in no tearing hurry to accord priority to touchscreen. ;)
Sun Jul 10, 2016 2:17 am
Again I want to stress a few things about the New Forum ...
(1) The use of ALL Gray Text, whether normal or bolded, is a REAL PITA! (put some color into the page W/O REQUIRING the User to do it via choosing various colors for differing portions of their posts) :rant :crazy :thumbsdown :thumbsdown
(2) Additionally, Gray Text on a White Background is damn hard to READ! (not enough CONTRAST) :help :help
(3) And lastly,
whichever font family is used for the text, please pick one that is a heavier typeface than simply a hairline
[/b]. Thin font faces are beyond aggro!!!! :rant :rant :rant :thumbsdown :thumbsdown :bs :facepalm
Sun Jul 10, 2016 2:18 am
QO check out this segregation (it's a screenshot of your own post):—
Sun Jul 10, 2016 2:23 am
:grouphug :grouphug
The above said, I certainly don't mind incorporating touchscreen functionality into a website/software program/device just as long as the older functionalities (mice/touchpads/etc) aren't turned into legacies. :thumbsup :thumbsup
Sun Jul 10, 2016 2:32 am
TrustFire wrote:QO check out this segregation (it's a screenshot of your own post):—
That's much better :thumbsup but I think could STILL be improved some, as follows ...
Take notice of how much vertical real estate is taken up by the Signature. It's almost as if the Signature was a far more important portion of the post than it really should be.
i.e. :idea: :idea:
(#1) Too Much Whitespace Between the Lines of Text (i.e. Too much Leading); and/or
(#2) Maybe the Font Size (of the Signature) could also be reduced by 1-2 points so it's less prominent).
Sun Jul 10, 2016 2:42 am
QuietOne wrote: (#1) Too Much Whitespace Between the Lines of Text (i.e. Too much Leading);
Screenshot? :scratch
QuietOne wrote: (#2) Maybe the Font Size (of the Signature) could also be reduced by 1-2 points so it's less prominent).
You can change the size (yourself,) under your User Control panel (check out my signature.) ;)
Sun Jul 10, 2016 4:22 am
Why???? Just look at the whitespace between the lines of text in the Signatures (plural and not just mine but everybody's).
"Leading" is the term/name typographers use for the whitespace between lines of text. The "Leading" is divided into separate components:
  • 1) The part from the TOP of the LINE OF TYPE (the top-most portion of the space allocated for a line of text) to the TOP-most EDGE of the FONT TEXT; and
  • 2) The part from the BOTTOM-most EDGE of the FONT TEXT to the BOTTOM of the LINE OF TYPE (the bottom-most portion of the space allocated for a line of text); where
  • 3) The LINE HEIGHT is equal to the TOTAL of:
    • 3A) #1 above;
    • 3B) The VERTICAL HEIGHT of the Font itself; and
    • 3C) #2 above.
Yeah I can ... For My Own Signature, but I can't change it for EVERYBODY's. :nono
It's too prominent for every post in the forums. It's as if it possessed as much importance ans the post itself, which it doesn't and/or shouldn't.
Sun Jul 10, 2016 4:48 am
Why????
As you might have already noticed, my browser has been extensively modded to neutralize the many quirks & bugs on the Board . . . . . . . . . . . . . moreover, I'm running many global scripts to synchronize dozens of other sites, to my own taste — without your screenshot, I won't have the foggiest idea of what you are referring to. :facepalm
Depending on one's HTML skills — why not? :scratch
Wanna see a demonstration of me — changing the font-size of your signature on my system? :devil
Sun Jul 10, 2016 5:18 am
Why????
OK, now I have a better understanding of why you asked. Thanks and Sorry about the confusion. :bow :bow
Here a couple SC's.
One of YOUR Posts:
One of MY Posts:
No, I don't need a demo :nono as I'm sure your HTML skills are better than mine, especially since I'm retired. Ahem, I don't put in the classroom (continuing ed.) time I suspect you do since you're still working. :facepalm :devil And besides that, there are many Forum contributors besides US on the Beta Team, who I'm also certain don't have your HTML skills.
Sun Jul 10, 2016 5:28 am
QuietOne wrote:OK, now I have a better understanding of why you asked. Thanks and Sorry about the confusion. :bow :bow
Apologies not needed, QO. :)
I see what you mean — those white spaces are killing my eyes. :yuck
Sun Jul 10, 2016 5:40 am
Here are some more issues with the white areas — this time, on the Notification Pop-up:—
