Restoring preview pane
perola
Fri Aug 21, 2009 3:01 am
I accidentally clicked the X below the incoming messaes, on the right side that says "Remove the preview pane." I didn't intend to do that. How do I restore the preview pane since I often find it handy to reply or view the raw source from there?
statman
Re: Restoring preview pane
Fri Aug 21, 2009 8:02 am
There should be an "Up Arrow Set" at the lower right to restore it
Statman
Statistical Services
Florida, USA
Windows 10/11
[Web Site](https://zstatman.duckdns.org/)
"No one cares how much you know until they know how much you care" [Unknown author]
Fri Aug 21, 2009 8:19 am
This is a MW question so it really should be down in the MailWasher section, not up here in the section about the website design and operation that most MW users skip looking at. No problem but if you want answers to more questions later you'd do better in the right place. :-)
Take a look at your View menu, it has an option to restore the preview pane as well as showing you the shortcut key to get it back.
perola
Fri Aug 21, 2009 12:45 pm
The View Menu option did it. Why didn't I think of that? Thanks! Sorry for posting in the wrong forum!
Fri Aug 21, 2009 1:25 pm
Not a problem for us, just that you'll get more responses in the right area.
Folks get notified of posts in areas they watch and only see the general areas once in a while.
