Stylish
Re: Stylish
Postby TrustFire Sat Jul 07, 2018 4:53 pm
Pierre wrote:TF, a new day makes a difference! I have the Firetrust Support Forum back up in its former self using Stylus. :thumbsup Had to start the update from fresh. It was a bit of try this and that. If I notice any bugs I will try to sort them out and/or let you know.
Good to know, Pierre — I noticed that the rules can even be copied (one-by-one — in Edit mode) from Stylish into Stylus (it makes the required adjustment/s.) :thumbsup
Pierre
Prudent Pukeko
Re: Stylish
Postby Pierre Sat Jul 07, 2018 5:47 pm
Yes. Also updated the laptop and that took about 2 minutes as the procedure was still lodged in my memory. It seems Stylish is also available for Chrome but I think the files would not be the same. Chrome has its own language.
Anyhow it is working like a charm. Thanks for your help. :bow :bow :bow :bow
smart1960
Re: Stylish
Postby smart1960 Fri Aug 03, 2018 4:00 am
:bow :bow :bow :bow :bow :bow :bow :bow :bow I think maybe it would be best as to where do we get the data from and if you could put the download links and how to install this new STYLUS onto here, please. Would be a big help if you could mate. :bow :bow :bow :bow :bow :bow :bow :bow :bow
Pierre
Prudent Pukeko
Re: Stylish
Postby Pierre Fri Aug 03, 2018 5:40 pm
I will send you the files first. Once you have them you will have to load them into Stylus. It is very similar to Stylish - just open Stylus go to Manage and then enter the 2 files and make sure you 'Save' each one. If you run into trouble I can send you some screenshots.
I could only find one link and from memory the other link just vanished. I will include the link as well. Trustfire was the person who put all the work into the original Stylish setup.
https://pastebin.com/DjsLK0sa
Firetrust-Green Theme .zip
(5.27 KiB) Downloaded 50 times
Re: Stylish
Postby TrustFire Mon Aug 06, 2018 7:07 pm
:thumbsup
Re: Stylish
Postby TrustFire Wed Aug 22, 2018 5:22 am
The latest Stylus is 1.4.20
    * Various fixes for narrow (mobile) UI
    * "Preserve new lines" option is added to beautifier in the editor
    * Buttons to restore/clone/move a section in the standard style editor
    * UserCSS style URLs can have ? after .user.css like dropbox URLs
    * UserCSS preprocessor LESS updated to 3.8.1
    * UserCSS site is now optional in @author
    * UserCSS will no longer overwrite existing styles when saving a new one
    * UserCSS now properly sets placeholder for empty `@name`
    * Fixes to a few issues with the "applies to" editor inputs.
    * Highlight edited style on history back (Firefox).
    * Add live reload message when unavailable.
    * Supress stylelint warning for Stylus language `@css` block.
    * Add "Translate" link to manager.
    * Apply style to more iframes (Firefox).
    * Display #RGBA swatches in the editor correctly even in old browsers.
    * Show update all button on individual check too.
    * Fix CSSLint issue with <text-decoration-color>.
    * Fix a rare issue with colorpicker positioning.
Who is online
Users browsing this forum: No registered users and 2 guests
