Filtering "Re:" Only
divnick
Mon Jan 18, 2010 4:00 pm
I receive quite a bit of spam with the subject "Re:" and nothing else. Is there a way to create a filter for that? Thanks. Steve
AlphaCentauri
Guardian Gecko
Re: Filtering "Re:" Only
Sun Apr 18, 2010 1:31 pm
AFAIK, if you set up the filter like this:
any rule below is satisfied
The subject field
is
Re:
The subject field
is
Re
Then if any spam has only "Re:" or "Re" as the subject, the filter will pick it up.
