FireFox is my default browser. Recently, every time I go to this site I'm asked to log-in? My UID and P/W is pre-filled in, FF saved it, and I do check 'log me in automatically' which is initially unchecked.
I have a desktop link to a specific forum and when I get e-mail that a post was made in a forum I was subscribed to that has a link, using either has this happen.
I don't know why all of a sudden? My computer or the s/w here causing this?
Suggestions?
Irv S.
Why do I have to LOG-IN every time all of a sudden?
Re: Why do I have to LOG-IN every time all of a sudden?
I don't think it is your computer, my systems are doing it too but only for the first visit of the day unless I close Firefox.
- irvsp
- Knowledgeable Kea
Stan,
I usually will close FF though, so it is more bothersome.
Irv S.
Good, it isn't always me then <VBG>stan_qaz wrote:I don't think it is your computer, my systems are doing it too but only for the first visit of the day unless I close Firefox.
Irv S.
Might be fixed now, it seems to be working for me after they tweaked a couple things.
- irvsp
- Knowledgeable Kea
Irv S.
Well it still is broke for me? I closed FF after I logged in, tried again, same login screen. So I checked the first box, logged in, closed FF, tried again, no deal.stan_qaz wrote:Might be fixed now, it seems to be working for me after they tweaked a couple things.
Irv S.
Do you have a tick in the "log me in automatically" box on the logon screen and do you have cookies allowed for the forums? That should be enough to have you let back in without a manual login.
- irvsp
- Knowledgeable Kea
I see 3 cookies for FIRETRUST.COM, named _utmz, _utma, and _jsuid. No others?
Wonder if they need to be deleted?
Also, could my ISP be using old data to speed loading? I have Brighthouse and they just released Lightning, which I got, a 40Mbps down/5Mbps up speed, wonder if they could be the cause?
Irv S.
Stan, yes, and I just booted the system and saw the e-mail and came here, same problem, login prompt, I check 'log me in automatically' as always, and then use previous page to see the message.stan_qaz wrote:Do you have a tick in the "log me in automatically" box on the logon screen and do you have cookies allowed for the forums? That should be enough to have you let back in without a manual login.
Irv S.
- irvsp
- Knowledgeable Kea
Oh, this is INTERESTING...
I opened IE 8 and copied the link from FF, closed FF and then pasted the link into IE. Forum message opened up immediately. I decided to REPLY and put this message in, but I was then asked to LOGIN?
Odd...
Could if be FF only related?
Irv S.
Odd...
Irv S.
- irvsp
- Knowledgeable Kea
Closed IE and re-opened FF to a different site and pasted in the link for this message. No surprise, LOGIN screen... and I checked the automatic again...
OK, something CLEARLY wrong here (or on my computer)...
With this open in FF (writing message) I opened IE and pasted in the link for this message. IE opened directly too it, BUT I hit RELPY, back to the LOGIN screen...
I'm baffled?
Maybe something has to propagate from down under to some servers I actually use?
Irv S.
I'm baffled?
Irv S.
I'm not sure what is going on, I normally use Firefox and don't have any other browsers that are set up for use so I can't try any other options.
My logging in is working but I'm still getting logged out after some period of inactivity. Have to let rusticdog see if he can see anything on the server side of things.
- irvsp
- Knowledgeable Kea
Still happening!
RusticDog, where are you?
Irv S.
Irv S.
Horse racing today in New Zealand. I'm thinking it is worse than Cricket as far as getting any of that lot to show up and do any work.
Hopefully rusticdog will win a good bit of money, enough to put him in a good mood BUT not enough for him to quit work or to take an extra months vacation!
They are really goofing off but he put in a bunch of changes that do look to be slowing down the spammers which is good, now they just have to go back and tweak the stuff that got broken like the favicons, local time clock and the logins.
- irvsp
- Knowledgeable Kea
Closed FF and tried again from the e-mail link. SAME THING.
Still not working for me? This is the ONLY site that I normally have to log in that is causing me a problem.
Irv S.
Nope, used the link from e-mail to get here via Firefox, got the sign-in page. Used ROBOFORM to fill-in the login screen, got in, then used the link to view previous page. Got here.rusticdog wrote:This all good for you now Irv ?
Irv S.
You use forum.firetrust.com or forums.firetrust.com as the subdomain ?
Edit : I've also slightly lessened the strength that logs out people, it may help.
