User Control Panel DST setting
genegold
Guardian Gecko
Mon Dec 20, 2010 7:27 am
I just noticed that the daylight savings time setting on does not automatically adjust with Windows (XP), but has to be user adjusted. Is that intentional?
johno
Re: User Control Panel DST setting
Mon Dec 20, 2010 11:08 am
genegold wrote:I just noticed that the daylight savings time setting on does not automatically adjust with Windows (XP), but has to be user adjusted.
I may be mistaken but I think this is the case with Vista as well.
johno
Mon Dec 20, 2010 11:33 am
There are so many DST change dates I don't know if the forum even tries to work with all of them.
Since I'm in Arizona it doesn't matter to me since we don't change. :thumbsup
Pierre
Prudent Pukeko
Mon Dec 20, 2010 1:01 pm
genegold wrote:I just noticed that the daylight savings time setting on does not automatically adjust with Windows (XP), but has to be user adjusted. Is that intentional?
And with Windows 7 as well. I have to set it in all forums I am a member of. No such thing as automatic as forum sites are scattered all over the world. PITA though.
genegold
Guardian Gecko
Mon Dec 20, 2010 2:00 pm
No, it's only forums that use the "Summer Time/DST is in effect" item. Perhaps they are using a more, uh, generic model. Checking around, there are plenty of forums that reset automatically. I don't know if that is the result of their using some master file or from working off the user's clock. In any case, here are a couple of examples that work correctly:
http://aumha.net/viewforum.php?f=65
http://forums.tweaktown.com/
And here's one exactly like Firetrust's:
http://www.xyplorer.com/xyfc/index.php
