You may want to ask that in one of the mailwasher forums, either 2010 for the new version or v5-v6 for the legacy versions.
In either case I don't know about Microsoft's MAPI so I'm no help there.
MSN accounts
Re: MSN accounts
Re: MSN accounts
You mean DeltaSync ? Assuming so, then no, it's a Microsoft Proprietary format and from what I recall there is no openly available information for getting into the inner workings. Apparently it's possible to buy a license from MS which may get all the needed info to add such a thing, however I wouldn't know costs etc..of such things.suncoastwck wrote:Does Mailwasher work with MSN email accounts that are setup usijng MSN's MAPI and NOT setup using a POP
