Hi
Mailwasher Pro, how many email accounts can you put in to check?
I am after one I can check 2 accounts in.
thanks
Shirl
How many accounts can u put in
Re: How many accounts can u put in
I'm not sure what the limit is in the two versions of MW Pro (v6 and 2011) both of which have dedicated forums here if you want to ask about a specific one.
Two accounts won't be a problem in either version, I have about 45 in each version here.
- LadyQuake
Hi
Thanks if it takes 2 thats ok, prob tryout V6 as older computer.
thanks
Shirl
thanks
Shirl
