Windows 8
alan.watson
Windows 8
Sat Oct 27, 2012 5:59 am
Having just installed Windows 8 - I wonder if there is any way that I can get Mailwasher Pro to show up on the Metro Interface or whatever it is called - Think it might be The Modern Interface.
I really want to somehow display the System Tray rotating Icon which says I have new E-Mails when I am in that Tiled Interface.
If I switch to the Desktop Interface I can see the System Tray - but not while I am on the Tiled Interface
Anyone any ideas.
Love Windows 8 by the way
Alan Watson
Re: Windows 8
Sat Oct 27, 2012 6:53 am
You might ask in the forum for mailwasher...
http://forum.firetrust.com/viewforum.php?f=50
Xlester
Re: Windows 8
Sat Feb 09, 2013 5:54 pm
Thanks for the good reviews with Windows 8. I am now thinking of switching from 7 to 8. ;)
Re: Windows 8
Fri Mar 29, 2013 12:46 am
Xlester wrote:Thanks for the good reviews with Windows 8. I am now thinking of switching from 7 to 8. ;)
I'm thinking of switching from Windows 8 to Windows Blue.
jack1e
Re: Windows 8
Wed Apr 17, 2013 7:44 pm
I am thinking of switching to W/9 because W/8 is poor and W/blue is supposed to be much of the same.
Anybody using W/8 and does not like it.Instead of going back to W7 just download Classic Shell which gives you the start menu and all programs back on W/8.
Matt619
Re: Windows 8
Tue Sep 17, 2013 7:24 pm
Can you try this updated version and see if it works? This bug should have been fixed here :thumbsdown
Re: Windows 8
Thu Sep 19, 2013 4:33 am
alan.watson wrote:If I switch to the Desktop Interface I can see the System Tray - but not while I am on the Tiled Interface
Anyone any ideas.
You can try the following trick:--
http://www.addictivetips.com/windows-ti ... within-it/ :thumbsup
lowestcassy
Re: Windows 8
Sun Sep 22, 2013 8:41 pm
I'm having a lot of trouble now with Windows 8. Almost all apps would not support this new OS. I just hope there won't be an issue with Firetrust too.
"Powerful Dreams Inspire Powerful Action." <removed> reviews
Re: Windows 8
Sun Sep 22, 2013 9:12 pm
MWP is fully supported on Windows 8. :|
