Recent update problems?
road runner 33
Sun Apr 23, 2017 7:17 pm
Currently using V 53.0 (32bit) updated today.
Since the update I have lost a desktop spreadsheet completely, had one which was saved elsewhere in 2015, suddenly appear on the desktop, lost access to all my accounting programs, lost the add-ons i had on Firefox. What has happened and how do I have it fixed.
ataraxy
Re: Recent update problems?
Mon Apr 24, 2017 2:53 am
Sounds like this is a Firefox issue. You can contact Firefox support at https://support.mozilla.org/en-US/products/firefox
Windows 10
Pierre
Prudent Pukeko
Mon Apr 24, 2017 8:56 pm
May be an idea to switch to Firefox 53.0 (64-bit) if your OS supports 64- bit. I switched from 32 to 64 a while ago. :idea:
Bendo
Mon Jun 05, 2017 5:03 pm
If your OS is 64 bit then download a 64 bit Firefox and check if this issue resolves.
