MailWasher Pro deleting emails without permission
troymedia
Postby troymedia Wed Sep 26, 2018 1:16 am
Every now and then MWPro deletes emails marked as Friend or Good, even though they haven't been marked for deletion.
How do I fix this, or is it a bug?
Re: MailWasher Pro deleting emails without permission
Postby rusticdog Wed Sep 26, 2018 12:35 pm
Hi there
Sounds odd, is the account setup as POP or IMAP under Settings >> Accounts >> Incoming.
There is an option below that if you click Advanced, Store Cached Emails, is that checked ?
troymedia
Postby troymedia Wed Sep 26, 2018 12:53 pm
IMAP.
Where would I find Advanced, Store Cached Emails in Settings? I am not sure to what "an option below" refers to.
Postby rusticdog Wed Sep 26, 2018 12:54 pm
OK, in Settings >> Accounts >> Incoming >> there is an option just below your logon details, Store Cached Emails, is that checked ?
troymedia
Postby troymedia Wed Sep 26, 2018 3:23 pm
Yes it is. But the box is greyed out so you can't unselect or select it. Is that the way it is supposed to be?
Postby rusticdog Wed Sep 26, 2018 3:27 pm
troymedia wrote:Yes it is. But the box is greyed out so you can't unselect or select it. Is that the way it is supposed to be?
OK sure thing. Try switching the account to type POP >> Save >> uncheck the option and set back to IMAP >> Save.
If that doesn't work, I would recommend you delete the account >> restart MailWasher and add the account back in, you can uncheck that option when the account type is set as POP.
troymedia
Postby troymedia Wed Sep 26, 2018 10:46 pm
OK. Followed your instructions. Now the Store Cached Emails option is unchecked for all IMAP accounts.
Will test and get back to you if the problem persists.
Who is online
Users browsing this forum: No registered users and 4 guests
