I am running Windows 7 Home Preminum and Mailwasher Pro 6.1. I have setup a Gmail account. Every time I ask Mailwasher to check mail I get this message:
Connection timed out (possibly caused by a firewall).
I cannot seem to be able to find the problem.
Thanks in advance,
Bill
Connection Timeout
Re: Connection Timeout
Can you check your gmail account from your e-mail program? If you can then make sure the Advanced Settings in MW match your e-mail program's exactly.
If you can't check from MW or your e-mail program check your gmail settings to make sure you have enabled POP access.
