Filter window
Moh
Filter window
Sat Oct 25, 2008 4:40 pm
The filter window in the 6.3 is bigger then my computer's wide screen. I can only see 9 rules instead of 10 even when the taskbar is unlockked. How I can make it smaller to fit the screen. I am running Windows XP. Any help will be greatly appreciated.
Thanks in advance
Moh
Re: Filter window
Sat Oct 25, 2008 7:36 pm
What screen resolution are you using?
Digerati
Retired Microsoft MVP
Re: Filter window
Sun Oct 26, 2008 12:42 am
While the filter window is fixed in size :( it should fit fine, well within the size of the screen. I agree, it would appear you have your Windows resolution set to low.
Image Bill (AFE7Ret)
Freedom is NOT Free!
