mailwasher not working
minutemenus
Thu Sep 12, 2024 6:08 am
tried:
reinstall
remove and recreate email accounts
not checking emails.
I need this working asap \Please help
Re: mailwasher not working
Fri Sep 13, 2024 8:10 am
Sure thing.... can you please let us know what MWpro version you are running (under Help>>About) and who your email provider is?
minutemenus
Sun Sep 15, 2024 4:59 am
7.15.10
host for my website is Hostway
Just need it working again.Willing to start over.
Will uninstall save settings reboot and reiinstall
If doesn't work will do same and not save settings and reinstall
Wish me luck. not much support available. been using since first created
Sun Sep 15, 2024 9:12 am
OK, if you are sure your provider details for incoming mail are correct within MWpro under the Incoming tab, yet MW still fails to check mail, can I please have some logs as per below directions:
- Use MWPro until you get the error
- Click "Send Logs"
