mailwasher pro and upgrading to win7
aquaplus
Wed Jul 21, 2010 9:29 am
I am upgrading from vista to win 7 via the upgrade method and not the reinstall method. I ran windows advisor and it didn't mention anything about mailwasher and was wondering if i should uninstall it before upgrading or can i leave it alone? Also, i think there will be no more outlook express with win 7. Will mailwasher pro work with windows live email?
Re: mailwasher pro and upgrading to win7
Wed Jul 21, 2010 1:16 pm
Did you read the forum title:
General Tech. Help
Try this forum:
http://forum.firetrust.com/viewtopic.php?f=31&t=6582
If you use the search function you should find any answers that are already posted.
aquaplus
Wed Jul 21, 2010 4:18 pm
sorry!
Thu Jul 22, 2010 5:01 am
Not a problem, it is just I can't answer your question and folks that could don't visit this forum very often.
