I'm using Windows 7, Outlook and MailWasher Pro 2010 V.1.0.35
I started using Outlook and upgraded Mailwasher at the same time, so not sure where the problem lies.
The problem is when I check mail every day, it downloads every header since I've started. Today, for instance, it downloaded about 300 headers. Only about 30 were for today. The rest were from the past week which is every email after I installed Mail Washer / Outlook.
Inbox doesn't refresh
Re: Inbox doesn't refresh
You have Outlook set to leave mail on your server, you need to change that before your server fills up. Somewhere in the Outlook account settings there is a tick-box to change it.
