Mail Wahing problem
Troubleshooting and help for FirstAlert spam database
bad
Mail Wahing problem
Fri Sep 09, 2011 10:02 pm
Hi Im trying to use MW pro 2011 in Windows 7, but after installation mails are not being washed away, it stays on MW. im using a POP mail a/c, if i have to delete those mails i have to go to the POP mail server & delete those mails then only MW also washes those mails. No problems in deleting blacklisted or spam mails, only the good mails are doesn't disappear from MW
Can you guide me to solve this issue.
Re: Mail Wahing problem
Sat Sep 10, 2011 3:41 am
This doesn't sound like a problem with the First Alert spam system, the topic of this forum. You should put MW questions in the MW 2011 forum.
http://forum.firetrust.com/viewforum.php?f=50
MW will only delete the messages you mark for delete, it will never delete mail not marked for deletion.
If you want your good mail deleted once your mail program has downloaded them then you need to set the mail program to do that. Look for some server option in your mail program, likely called "leave mail on server" or something similar.
bad
Mon Sep 12, 2011 1:13 am
Thanks Stan
I have posted the problem to the link which you gave me.
