I several times reported uncorectly classified e-mail by First Alert and even if we answer me that those messages have been removed from the system, the similar messages I receive are still classified as "known spam"...
Reporting error problem
- clauderenaud
Re: Reporting error problem
I can only assume someone keeps reporting the same messages as spam that you are getting.
If you add the sending address to your Friends List, they won't be checked against FirstAlert.
The Hot Key for adding a sender to the address list is the + key
- clauderenaud
Frankly, I don't think so as those messages are for the moment FireTrust forum responses only ...rusticdog wrote:I can only assume someone keeps reporting the same messages as spam that you are getting.
Regards,
Claude Renaud
Claude Renaud
Whoopsie...
Claude, You just gave me my Monday chuckle.
- clauderenaud
The problem seems to be solved for now (I just submited few more examples to the FirstAlert department and Jeremy apparently found the solution)...
Regards,
Claude Renaud
Claude Renaud
