Importing Black List
- jackowens
I have the black list from Mailwasher Pro 5.3 as a text-file on my desktop but can't figure out the step-by-step procedure for importing it into MailWasher Pro 2010.1.0.19. Does anyone know? The import button doesn't seem to work. Is the procedure given clearly in the setup/instructions somewhere?
Re: Importing Black List
Your best bet is to put the blacklist file in the default location that MW 5.3 would have put it and them 2010 will import it. I don't have access to my Windows system or I'd post the location.
It is mentioned in both MW forums if you care to check there, this forum is only for First Alert problems so most folks don't even look at it.
