Error Logs
wilsonbrucea
Error Logs
Tue Apr 07, 2009 12:27 am
Is logging turned on by default? If so where do I find the logs. We have had MWES shut down by windows for some reason several times over the past few weeks and I am trying to see what MWES has been up to.
Bruce Wilson
Barrie, Ontario, Canada
Re: Error Logs
Wed Apr 08, 2009 3:02 pm
HI Bruce, Can you please try this version - it hopefully fixes the shutting down problem.
You can just run the installer and it will update everything, but can you please set the logging level = 1 in Windows Registry: "HKEY_LOCAL_MACHINE\SOFTWARE\Firetrust Limited\mwes" and restart MailWasher
Download from
http://s3.amazonaws.com/Firetrust/mwes/ ... er_264.exe
Logs are at: c:\Program Files\MailWasher Enterprise Server\Logs
And you can send them to me at [email protected]
Return to “Post Installation”
