Web Interface is failing after removing all rbls in list
mshanley
Sun Feb 24, 2013 4:37 am
I do not see any documentation on this so not sure how to troubleshoot.
What I have done is REMOVED ALL RBLS in the list as I am doing some testing, but apparently this breaks the GUI and I cannot get back in.
Can you confirm?
I have tried re-installing and it still fails - blank page - like the webserver is not working?
It would be nice to have this product use IIS?
Re: Web Interface is failing after removing all rbls in list
Sun Feb 24, 2013 7:05 pm
Do you recall what you had as ‘Webhost Name’?
If not, you can look inside the database
Get the free http://www.sqliteexpert.com/download.html and navigate to the configure table.
You’ll see all the settings there.
Also, go to Start>>Run, type Services.msc and check the 'MailWasher Enterprise Server 'Service is running
Regards
Nick
Return to “Post Installation”
