MWES crashing
PC-TECH
MWES crashing
Thu May 07, 2009 2:16 pm
Crashes 10 times a day at a customers location. If it wasn't for the MWES recovery restarting MWES after first/second/third failures then it would become more apparent that it is failing.
When will a fix come out that doesn't require these tricks?
Re: MWES crashing
Fri May 08, 2009 10:50 am
Hi there
We've now located and fixed this fault and you can get the updated version 2.68 at http://firetrust.com/en/download/mailwa ... ise_server
Regards
Nick
Return to “Post Installation”
