Quarantine Max Lines limit and no additonal pages
simongurner
Mon Jun 01, 2009 8:22 pm
Just checking through the system after the upgarde at the weekend and we've found a potential issue. Firstly, when using the quarantine the maximum lines you can display is now 500, but if you put any more it will automatically default to diplaying 50. Also, if you need to look through the quarantine, you do not get any options for going on to additional pages. We had just under 1500 spam come through on sunday alone, but we can only therefore view a maximum of 500. We know the filtering option is there (great by the way), but if we need to browse for any reason then this is now not possible (especially as we now don't have the seperate user accounts either and will need to do this for our customers in the short term, hopefully...).
Regards
Simon
ajt
would rather be watching cricket
Re: Quarantine Max Lines limit and no additonal pages
Tue Jun 02, 2009 9:04 am
There are options to filter messages by date.
Splitting pages is in the TODO list.
leeraven
Fri Jul 03, 2009 1:41 am
How many items are held in quarantine? and for how long?
ajt
Fri Jul 03, 2009 11:47 am
There is no limit in db for number of quarantine items. Message will stay for 7 days in the quarantine and then automatically deleted.
Return to “Post Installation”
