There are huge number of Spam after upgrade to 3.0
cwh168998
Wed Oct 28, 2015 4:20 am
Dear Sir,
After we upgraded from mwes64-2814 to mwes64-3000, we can not activate user, and the RBL is empty, we can not add RBL URL. It shows successful. But when we back to check, it is not there.
There are huge number of Spam after upgrade. What might be the issue?
It is Linux 3.19.8-100.fc20.x86_64 #1 SMP Tue May 12 17:08:50 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux.
I follow the upgrade instruction.
the owner of the folder is mwes:
[root@webmail mwes]# ls -l
total 1372648
-rw-r--r--. 1 mwes mwes 1389 Oct 26 15:23 CustomSpamFilter.xml
drwxr-xr-x. 2 mwes mwes 4096 Oct 26 15:23 fonts
lrwxrwxrwx. 1 mwes mwes 20 Oct 26 15:23 libchartdir.so -> libchartdir.so.5.0.0
lrwxrwxrwx. 1 mwes mwes 20 Oct 26 15:23 libchartdir.so.5.0 -> libchartdir.so.5.0.0
-rwxr-xr-x. 1 mwes mwes 3922536 Oct 26 15:23 libchartdir.so.5.0.0
-rwxr-xr-x. 1 mwes mwes 1626400 Oct 26 15:23 libcrypto.so.0.9.8
-rwxr-xr-x. 1 mwes mwes 93000 Oct 26 15:23 libresolv.so.2
-rwxr-xr-x. 1 mwes mwes 342192 Oct 26 15:23 libssl.so.0.9.8
lrwxrwxrwx. 1 mwes mwes 19 Oct 26 15:23 libstdc++.so.6 -> libstdc++.so.6.0.13
-rwxr-xr-x. 1 mwes mwes 1027760 Oct 26 15:23 libstdc++.so.6.0.13
drwxr-xr-x. 6 mwes mwes 4096 Oct 26 15:23 mwes
-rw-r--r--. 1 mwes mwes 1395466240 Oct 27 11:19 mwes.db
drwxr-xr-x. 6 mwes mwes 4096 Oct 26 15:23 mwes-new
-rwsr-sr-x. 1 mwes mwes 2913952 Oct 26 15:23 mwes.run
-rwxr-xr-x. 1 mwes mwes 159424 Oct 26 15:23 testspf
-rwxr-xr-x. 1 mwes mwes 270 Oct 26 15:23 uninstall
Please help to fix it or show me the command to modify it manually. Thank you.
Best regards,
James
Return to “Post Installation”
