MWES on SBS2008
John McNeill
MWES on SBS2008
Sat Aug 15, 2009 2:00 am
Hi Nick
Have installed Mailwasher Enterprise on a server with SBS2008 installed but software crashes every 20 minutes or so and generates an error report.
I am using MWES version 2.7.2, and is fully registered ie not a trial.
Any ideas?
Re: MWES on SBS2008
Sat Aug 15, 2009 8:18 pm
Hi John
Thanks for letting me know & very strange as we've not had any other reported crashes.
Can you set the logging to = 1
Go to:
Windows Registry: "HKEY_LOCAL_MACHINE\SOFTWARE\Firetrust Limited\mwes"
When changed, restart the MailWasher Enterprise Server Service (Go to Start>>Run>>Type 'services.msc' and locate MailWasher Enterprise Server, and restart).
A log file is created at "C:\Program Files\MailWasher Enterprise Server\logs\"
Please zip these up and send the log to nick.bolton@firetrust.com and we'll investigate and fix asap.
Nick
Re: MWES on SBS2008
Sat Aug 15, 2009 8:29 pm
Oops, the registry key should be log_level=1
John McNeill
Re: MWES on SBS2008
Mon Aug 17, 2009 8:48 pm
Hi Nick
I have turned logging on now and will email you the log later today
John McNeill
John McNeill
Re: MWES on SBS2008
Fri Sep 18, 2009 8:11 pm
Sorry I meant to update this topic earlier.
The issue is now resolved thanks to the excellent support from all at Firetrust
Return to “Post Installation”
