Remove or hide footer info in MWES
triadgroup
Wed May 12, 2010 4:54 am
After installing and configuring the mwes, I have noticed that it adds the following to each email:
X-MWES-scanned: Checked by MailWasher Enterprise Server 2.7.6 {U}(2010-05-11 15:38:42)
X-MWES-status: Clean
X-MWES-reason: Local IP
X-MWES-sourceip: 192.168.2.16
X-MWES-smtp-from: <[email protected]>
How do I hode them in the headers. Our employees are not going to want that displayed after their signatures.
Re: Remove or hide footer info in MWES
Wed May 12, 2010 12:00 pm
just replying here, also in email
The X-MWES headers are in the header section of the email, they are never shown in the body.
What is your setup server side and client side?
Can you give us an example?
We’ve seen this before with qmail (MTA) not setup correctly, so we can have a look at this if you like.
Thu May 13, 2010 11:05 am
Just recreated the problem.
When using telnet you're not using new line after entering command DATA. This separates the header from the body example.
Note new line is required and is done automatically by mail clients.
S: 220 smtp.example.com ESMTP Postfix
C: HELO relay.example.org
S: 250 Hello relay.example.org, I am glad to meet you
C: MAIL FROM:<[email protected]>
S: 250 Ok
C: RCPT TO:<[email protected]>
S: 250 Ok
S: 250 Ok
C: DATA
S: 354 End data with <CR><LF>.<CR><LF>
C:
C: Hello Alice.
C: This is a test message with 0 header fields and 4 lines in the message body.
C: Your friend,
C: Bob
C: .
S: 250 Ok: queued as 12345
C: QUIT
S: 221 Bye
Return to “Post Installation”
