Digest reports
keystonesystems
Digest reports
Mon Jan 31, 2011 12:24 pm
Just installed the trial of MWES on Exchange 2003 SP2. For some reason we are not getting the Digest Reports. We have a user setup and even set the time to 1 hour and nothing...
Advice?
cliff
Evil Firetrust Employee
Re: Digest reports
Mon Jan 31, 2011 1:45 pm
Hi there,
Some settings to check for the Digest:
* You have Digest Report checked (System > Configuration)
* Each user has a primary email address entered into the User Settings (Settings > User) - this must be receivable by the connected MTA
* Each user has an appropriate value entered into the User Settings (Settings > User) - usually their address, or even their name is appropriate
As mentioned, your MTA must be able to receive mail to the supplied addresses.
~ Cliff
keystonesystems
Re: Digest reports
Mon Jan 31, 2011 1:56 pm
UserID:
Password:
Confirm password:
Primary email address:
All have values entered. email address is also a correct value.
--> MTA Hostname is the location and port of your MTA/mail server. Would this be the internal hostname address?
keystonesystems
Re: Digest reports
Tue Feb 01, 2011 1:56 am
Anyone out there have any ideas?
cliff
Re: Digest reports
Tue Feb 01, 2011 9:07 am
The MTA hostname should be the IP/DNS that MWES connects to. If you are receiving mail through MWES, then this is set correctly.
I'll get in touch via email :)
~ C
Return to “Post Installation”
