What is this feature?
I haven't found any documentation on it online. It's found under the Settings tab so I assume it is different then just the white/black list of IP's.
Trusted Ip's
- cliff
- Evil Firetrust Employee
Re: Trusted Ip's
Hi There,
A trusted IP allows mail sent from the specified IP to pass through without the need to authenticate - it's often called a 'relay client'.
In Linux installations, no more needs to be done, as MWES will be trusted by the MTA.
In Exchange installations, you may need to adjust the exchange receive connector to trust MWES explicitly.
~C
~C
