Hello,
I have no inbound email.
I have done a system check and everything passed. I guess I will setup logging, but I am not sure what to do next.
Andrew
No inbound email
- dragonflybog
Re: No inbound email
Here's the log
11:14 AM 6/3/20102010-06-03 10:02:54 [6636] Info: Shutdown Auto-reporting....
2010-06-03 10:02:54 [6636] Info: Shutdown HouseKeepingTask....
2010-06-03 10:02:54 [6636] Info: Shutdown WebManager....
2010-06-03 10:02:55 [6636] Info: Shutdown MTA proxy....
2010-06-03 10:02:55 [6636] Info: Shutdown FilterManagerThreads....
2010-06-03 10:02:55 [5724] Debug: Successfully disconnected from CFS...
2010-06-03 10:02:55 [5724] Info: FilterManagerThread::ObjectThreadMethod - ending
2010-06-03 10:02:55 [6636] Info: Shutdown UploadManagerThread....
2010-06-03 10:02:55 [5660] Debug: Successfully disconnected from CFS...
2010-06-03 10:02:55 [5660] Info: UploadManagerThread::ObjectThreadMethod - ending
2010-06-03 10:02:55 [6636] Info: Shutdown StatThread....
2010-06-03 10:02:55 [6636] Info: Close database....
2010-06-03 10:02:55 [6636] Info: Ending MWES....
2010-06-03 10:02:56 [8004] Info: starting mwes version 2.7.6 {W}
2010-06-03 10:02:56 [8004] Info: environment....
2010-06-03 10:02:56 [8004] Info: cfs_max_cache_size::20000
2010-06-03 10:02:56 [8004] Info: database_location::C:\Program Files\MailWasher Enterprise Server\data
2010-06-03 10:02:56 [8004] Info: default_page::Quarantined.srv
2010-06-03 10:02:56 [8004] Info: home::C:\Program Files\MailWasher Enterprise Server
2010-06-03 10:02:56 [8004] Info: hostname::remote.cbkit.com
2010-06-03 10:02:56 [8004] Info: listen_port::4044
2010-06-03 10:02:56 [8004] Info: log_level::1
2010-06-03 10:02:56 [8004] Info: logging::C:\Program Files\MailWasher Enterprise Server\logs
2010-06-03 10:02:56 [8004] Info: mta_hostname::localhost
2010-06-03 10:02:56 [8004] Info: mta_port::26
2010-06-03 10:02:56 [8004] Info: proxy_hostname::
2010-06-03 10:02:56 [8004] Info: proxy_port::25
2010-06-03 10:02:56 [8004] Info: rbl_max_cache_size::20000
2010-06-03 10:02:56 [8004] Info: root_document::C:\Program Files\MailWasher Enterprise Server\site
2010-06-03 10:02:56 [8004] Info: use_check_domains::1
2010-06-03 10:02:56 [8004] Info: use_mta_proxy::1
2010-06-03 10:02:56 [8004] Info: web_hostname::localhost
2010-06-03 10:02:56 [8004] Info: web_port::4044
2010-06-03 10:02:56 [8004] Info: Initialising WebManager....
2010-06-03 10:02:56 [8004] Info: Initialising database....
2010-06-03 10:02:56 [8004] Info: Initialising database configure table....
2010-06-03 10:02:56 [8004] Info: DatabaseManager::UpgradeDatabase - version 21 ok
2010-06-03 10:02:56 [8004] Info: Initialising database white listing table....
2010-06-03 10:02:56 [8004] Info: Initialising database black listing table....
2010-06-03 10:02:56 [8004] Info: Initialising database filter black listing table....
2010-06-03 10:02:56 [8004] Info: Initialising database rbl listing table....
2010-06-03 10:02:56 [8004] Info: Initialising database quarantined table....
2010-06-03 10:02:56 [8004] Info: Initialising database gray listing table....
2010-06-03 10:02:56 [8004] Info: Initialising database white listing ip table....
2010-06-03 10:02:56 [8004] Info: Initialising database black listing ip table....
2010-06-03 10:02:56 [8004] Info: Initialising database user table....
2010-06-03 10:02:56 [8004] Info: Initialising database Gray listing friends table....
2010-06-03 10:02:56 [8004] Info: Initialising database Domain table....
2010-06-03 10:02:56 [8004] Info: Initialising database stat tables....
2010-06-03 10:02:56 [8004] Info: Initialising Auto-reporting....
2010-06-03 10:02:56 [8004] Info: ShutdownTime::40332.418681, CurrentTime::40332.418704, Clock::0.000023
2010-06-03 10:02:57 [8004] Info: Starting StatThread....
2010-06-03 10:02:57 [8004] Info: Starting FilterManagerThreads....
2010-06-03 10:02:57 [8168] Info: Starting TaskThread....
2010-06-03 10:02:57 [8004] Info: Starting UploadManagerThread....
2010-06-03 10:02:57 [8004] Info: Starting MTA proxy....
2010-06-03 10:02:57 [8004] Info: Starting HouseKeepingTask....
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - HTTP/1.1 200 OK
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Date: Thu, 03 Jun 2010 14:02:57 GMT
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Server: Apache
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Last-Modified: Fri, 16 Apr 2010 07:38:51 GMT
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - ETag: "30e191-ab-48455b3d4d8c0"
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Accept-Ranges: bytes
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Content-Length: 171
2010-06-03 10:02:57 [440] Debug: HTTPSocket::HTTPSocket - Content-Type: application/xml
2010-06-03 10:02:57 [440] Debug: VersionStatus::Collect - xml size(171)
<mwes>
<VersionNumber>2.7.6</VersionNumber>
<VersionURL>http://www.firetrust.com/en/products/ma ... VersionURL>
</mwes>
2010-06-03 11:02:57 [440] Debug: HouseKeepingTask::QuarantinedEmail - HoneyPotUpload count(0)
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - HTTP/1.1 200 OK
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Date: Thu, 03 Jun 2010 15:02:58 GMT
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Server: Apache
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Last-Modified: Fri, 16 Apr 2010 07:38:51 GMT
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - ETag: "30e191-ab-48455b3d4d8c0"
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Accept-Ranges: bytes
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Content-Length: 171
2010-06-03 11:02:58 [440] Debug: HTTPSocket::HTTPSocket - Content-Type: application/xml
2010-06-03 11:02:58 [440] Debug: VersionStatus::Collect - xml size(171)
<mwes>
</mwes>
<mwes>
</mwes>
<mwes>
</mwes>
- dragonflybog
Solution.
Some how my windows server firewall got turned on.
I have windows live care or whatever it was installed. But they discontinued the service. I uninstalled it. The uninstall must have turned on the windows firewall.
Hope this helps anyone else with a similar issue.
Andrew
Andrew
