Hi All,
I'm trying to use MailWasher ES with Scalix 11.4.
I have had Scalix running fine, using Sendmail Milter for Amavisd-new (virus scanning) and MIMEDefang for a 'boilerplate'.
I now want to add MailWasher ES. The basic problem is this :
In its standard configuration, Scalix listens on port 25 and then forwards all emails to Sendmail. When Sendmail passes the email to MWES (using milter) the source IP always appears as localhost, so MWES always PASSes the email.
To avoid this, I needed to change the Scalix config so that sendmail listens on port 25, and then forwards to Scalix. This caused problems with authentication when sending mail from Outlook as well as Scalix Webmail.
Has anyone else had this problem? Any HOWTOs on the subject? I have put up a message on the scalix forums :
http://www.scalix.com/forums/viewtopic.php?f=9&t=13856
Regards & thanks in advance,
Arif
MWES with Scalix
- ajt
- would rather be watching cricket
Re: MWES with Scalix
You could try running MWES as a proxy in front of Scalix
MWES Proxy (SMTP port 25) -> Scalix MTA/Relay(Port 26) -> Sendmail (Port 27)
The Readme file will explain this just replace the wording for MTA with Scalix
Change mwes.conf
use_mta_proxy=1
Remove the sendmail milter interface. Then stop/start MWES.
Curently MWES proxy is not support SSL/TLS connections.
Change mwes.conf
use_mta_proxy=1
