It was working for a few months....
Problems/tips/tricks with MailWasher Enterprise and Linux
jmason1182
Thu Sep 23, 2010 9:54 am
Everything was working for a few months. I had just upgraded to 2.7.81 in early August and finally got everything done in the proxy method.
My server IP is X.X.X.51. It has sendmail running on port 26, with mwes running on X.X.X.51 as well on port 25. Like I said, it was all working great until today.
To my knowledge there hasn't been any changes yet. But I am not receiving any mail, not even the simple tests. I see them in the logs, but EVERY email has this error:
Code: Select all
Sep 22 16:51:30 server51 sendmail[2509]: o8MLpJEU002509: lost input channel from mail.mydomain.com [X.X.X.51] to MTA after mail
Sep 22 16:51:30 server51 sendmail[2509]: o8MLpJEU002509: from=<yvurybiy1728@windstream.net>, size=294, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=mail.mydomain.com [X.X.X.51]
and when I look a the web interface I see: "System status: No MTA server available" but check and yep, sendmail and all are running just fine.
What's the problem here?
jmason1182
Re: It was working for a few months....
Thu Sep 23, 2010 9:56 am
And yes, I realize that some spammers do this by not ending the messages cleanly.... BUT this is after mail, not after rcpt. If it said "lost input channel from .... to MTA after rcpt" I would think along those lines. But since this is EVERY message, as well as "after mail" I am at a loss.
jmason1182
Sat Sep 25, 2010 1:27 am
After completely shutting the server down for an entire period of about 12 hours, I brought it back up and it immediately resumed with the same errors. Then I had an idea, what if I turn off the firewall (iptables)? Well that didn't change anything but it did make me consider some other network related issues. When all my network tests and checks turned out to be working perfectly, I started looking at the server configuration.
I switched the configuration of mwesd from using the MTA hostname as mail.mydomain.com to localhost. Suddenly thoussands of messages went forth. So at least we are sending and receiving email again.
BUT two questions now plague me, first: Why did it work for more than 30 days with the other setting and then "break"? No dns changes have been made, nothing to the hosts file, and in fact I haven't had to login to that server since I updated mwesd over a month ago! So why did it work and then suddenly stop?!
Secondly, why do i still see all these same errors? Here's a snippet from the maillog file (with emails masked, etc.)
Code: Select all
...snip...
Sep 24 08:05:45 mailserver sendmail[3565]: o8OD5gSN003565: collect: premature EOM: unexpected close
Sep 24 08:05:45 mailserver sendmail[3565]: o8OD5gSN003565: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:05:45 mailserver sendmail[3565]: o8OD5gSN003565: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:05:49 mailserver sendmail[3563]: o8OD5XOV003563: collect: premature EOM: unexpected close
Sep 24 08:05:49 mailserver sendmail[3563]: o8OD5XOV003563: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:05:49 mailserver sendmail[3563]: o8OD5XOV003563: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:05:49 mailserver sendmail[3567]: o8OD5ksH003567: collect: premature EOM: unexpected close
Sep 24 08:05:49 mailserver sendmail[3567]: o8OD5ksH003567: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:05:49 mailserver sendmail[3567]: o8OD5ksH003567: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:05:59 mailserver sendmail[3571]: o8OD5tWK003571: collect: premature EOM: unexpected close
Sep 24 08:05:59 mailserver sendmail[3571]: o8OD5tWK003571: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:05:59 mailserver sendmail[3571]: o8OD5tWK003571: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:03 mailserver sendmail[3573]: o8OD61tC003573: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:04 mailserver sendmail[3573]: o8OD61tD003573: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:05 mailserver sendmail[3573]: o8OD61tE003573: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:06:05 mailserver sendmail[3573]: o8OD61tE003573: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:05 mailserver sendmail[3569]: o8OD5nuW003569: collect: premature EOM: unexpected close
Sep 24 08:06:05 mailserver sendmail[3569]: o8OD5nuW003569: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:06:05 mailserver sendmail[3569]: o8OD5nuW003569: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:16 mailserver sendmail[3577]: o8OD6Epq003577: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:17 mailserver sendmail[3577]: o8OD6Epr003577: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:18 mailserver sendmail[3577]: o8OD6Eps003577: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:06:18 mailserver sendmail[3577]: o8OD6Eps003577: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:21 mailserver sendmail[3575]: o8OD66HQ003575: collect: premature EOM: unexpected close
Sep 24 08:06:21 mailserver sendmail[3575]: o8OD66HQ003575: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:06:21 mailserver sendmail[3575]: o8OD66HQ003575: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:38 mailserver sendmail[3579]: o8OD6MlY003579: collect: premature EOM: unexpected close
Sep 24 08:06:38 mailserver sendmail[3579]: o8OD6MlY003579: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:06:38 mailserver sendmail[3579]: o8OD6MlY003579: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:40 mailserver sendmail[3586]: o8OD6dli003586: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:42 mailserver sendmail[3586]: o8OD6dlj003586: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:43 mailserver sendmail[3586]: o8OD6dlk003586: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:06:43 mailserver sendmail[3586]: o8OD6dlk003586: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:06:56 mailserver sendmail[3588]: o8OD6dFr003588: collect: premature EOM: unexpected close
Sep 24 08:06:56 mailserver sendmail[3588]: o8OD6dFr003588: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:06:56 mailserver sendmail[3588]: o8OD6dFr003588: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:07 mailserver sendmail[3593]: o8OD6uXr003593: collect: premature EOM: unexpected close
Sep 24 08:07:07 mailserver sendmail[3593]: o8OD6uXr003593: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:07:07 mailserver sendmail[3593]: o8OD6uXr003593: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:08 mailserver sendmail[3597]: o8OD78Mj003597: localhost.localdomain [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
Sep 24 08:07:11 mailserver sendmail[3601]: o8OD7A66003601: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:12 mailserver sendmail[3601]: o8OD7A67003601: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:13 mailserver sendmail[3601]: o8OD7A68003601: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:07:13 mailserver sendmail[3601]: o8OD7A68003601: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:13 mailserver sendmail[3595]: o8OD77DX003595: collect: premature EOM: unexpected close
Sep 24 08:07:13 mailserver sendmail[3595]: o8OD77DX003595: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:07:13 mailserver sendmail[3595]: o8OD77DX003595: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:18 mailserver sendmail[3603]: o8OD7DTS003603: collect: premature EOM: unexpected close
Sep 24 08:07:18 mailserver sendmail[3603]: o8OD7DTS003603: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:07:18 mailserver sendmail[3603]: o8OD7DTS003603: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:23 mailserver sendmail[3605]: o8OD7ISU003605: collect: premature EOM: unexpected close
Sep 24 08:07:23 mailserver sendmail[3605]: o8OD7ISU003605: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:07:23 mailserver sendmail[3605]: o8OD7ISU003605: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:07:30 mailserver sendmail[3607]: o8OD7NNv003607: collect: premature EOM: unexpected close
Sep 24 08:07:30 mailserver sendmail[3607]: o8OD7NNv003607: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:07:30 mailserver sendmail[3607]: o8OD7NNv003607: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:08:03 mailserver sendmail[3549]: o8NIhNVn024096: to=<_email_masked_> (10000/100), delay=18:24:38, xdelay=00:04:05, mailer=esmtp, pri=1917961, relay=otherdomain.com. [207.46.31.61], dsn=4.0.0, stat=Deferred: Connection timed out with otherdomain.com.
Sep 24 08:08:04 mailserver sendmail[3610]: o8OD7Xpg003610: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:08:46 mailserver sendmail[3617]: o8OD8jaU003617: from=<_email_masked_>, size=6945, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:03 mailserver sendmail[3621]: o8OD92nm003621: from=<_email_masked_>, size=405, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:14 mailserver sendmail[3610]: o8OD7Xph003610: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:09:14 mailserver sendmail[3610]: o8OD7Xph003610: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:17 mailserver sendmail[3623]: o8OD9G9m003623: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:09:17 mailserver sendmail[3623]: o8OD9G9m003623: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=SMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:44 mailserver sendmail[3630]: o8OD9hn8003630: from=<_email_masked_>, size=7552, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:55 mailserver sendmail[3632]: o8OD9pRT003632: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:09:58 mailserver sendmail[3632]: o8OD9pRU003632: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:10:03 mailserver sendmail[3632]: o8OD9pRV003632: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:10:03 mailserver sendmail[3632]: o8OD9pRV003632: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:10:05 mailserver sendmail[3639]: o8ODA3Ic003639: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:10:06 mailserver sendmail[3639]: o8ODA3Id003639: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:10:07 mailserver sendmail[3639]: o8ODA3Ie003639: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:10:07 mailserver sendmail[3639]: o8ODA3Ie003639: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:10:31 mailserver sendmail[3628]: o8OD9YmK003628: localhost.localdomain [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
Sep 24 08:12:06 mailserver sendmail[3648]: o8ODC0Vt003648: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:08 mailserver sendmail[3648]: o8ODC0Vu003648: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:09 mailserver sendmail[3650]: o8ODC9nT003650: localhost.localdomain [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
Sep 24 08:12:10 mailserver sendmail[3648]: o8ODC0Vv003648: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:12:10 mailserver sendmail[3648]: o8ODC0Vv003648: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:27 mailserver sendmail[3654]: o8ODCOm3003654: collect: premature EOM: unexpected close
Sep 24 08:12:27 mailserver sendmail[3654]: o8ODCOm3003654: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:12:27 mailserver sendmail[3654]: o8ODCOm3003654: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:30 mailserver sendmail[3658]: o8ODCRPl003658: collect: premature EOM: unexpected close
Sep 24 08:12:30 mailserver sendmail[3658]: o8ODCRPl003658: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:12:30 mailserver sendmail[3658]: o8ODCRPl003658: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:33 mailserver sendmail[3660]: o8ODCUCY003660: collect: premature EOM: unexpected close
Sep 24 08:12:33 mailserver sendmail[3660]: o8ODCUCY003660: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:12:33 mailserver sendmail[3660]: o8ODCUCY003660: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:41 mailserver sendmail[3656]: o8ODCQiJ003656: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:12:41 mailserver sendmail[3656]: o8ODCQiJ003656: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:42 mailserver sendmail[3666]: o8ODCeCh003666: collect: premature EOM: unexpected close
Sep 24 08:12:42 mailserver sendmail[3666]: o8ODCeCh003666: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:12:42 mailserver sendmail[3666]: o8ODCeCh003666: from=<_email_masked_>, size=5, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:46 mailserver sendmail[3670]: o8ODCfK5003670: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:52 mailserver sendmail[3670]: o8ODCfK6003670: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:12:54 mailserver sendmail[3670]: o8ODCfK7003670: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:12:54 mailserver sendmail[3670]: o8ODCfK7003670: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:13:49 mailserver sendmail[3672]: o8ODDlsw003672: from=<_email_masked_>, size=393, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:13:59 mailserver sendmail[3674]: o8ODDsj3003674: collect: premature EOM: unexpected close
Sep 24 08:13:59 mailserver sendmail[3674]: o8ODDsj3003674: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:13:59 mailserver sendmail[3674]: o8ODDsj3003674: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:06 mailserver sendmail[3680]: o8ODE4CO003680: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:07 mailserver sendmail[3680]: o8ODE4CP003680: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:08 mailserver sendmail[3680]: o8ODE4CQ003680: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:14:08 mailserver sendmail[3680]: o8ODE4CQ003680: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:09 mailserver sendmail[3678]: o8ODE019003678: collect: premature EOM: unexpected close
Sep 24 08:14:09 mailserver sendmail[3678]: o8ODE019003678: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:14:09 mailserver sendmail[3678]: o8ODE019003678: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:32 mailserver sendmail[3682]: o8ODEUat003682: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:33 mailserver sendmail[3682]: o8ODEUau003682: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:34 mailserver sendmail[3682]: o8ODEUav003682: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:14:34 mailserver sendmail[3682]: o8ODEUav003682: from=<_email_masked_>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:42 mailserver sendmail[3684]: o8ODEdmi003684: collect: premature EOM: unexpected close
Sep 24 08:14:42 mailserver sendmail[3684]: o8ODEdmi003684: collect: unexpected close on connection from localhost.localdomain, sender=<_email_masked_>
Sep 24 08:14:42 mailserver sendmail[3684]: o8ODEdmi003684: from=<_email_masked_>, size=0, class=0, nrcpts=1, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:14:57 mailserver sendmail[3686]: o8ODEt09003686: from=<_email_masked_>, size=394, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Sep 24 08:15:43 mailserver sendmail[3697]: o8ODFPcf003697: lost input channel from localhost.localdomain [127.0.0.1] to MTA after mail
Sep 24 08:15:43 mailserver sendmail[3697]: o8ODFPcf003697: from=<_email_masked_>, size=2517, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
...snip...
So can anyone suggest what to do about this issue? This is basically all my maillogs contain!
cliff
Evil Firetrust Employee
Mon Sep 27, 2010 3:33 pm
Hi There,
What version did you upgrade from? - if it was anythign lower than 2.7.8 there are some additional operations to perform - namely in the configuration screen of the MWEs control panel.
~ Cliff
Return to “Linux Specific”
