Is it possible to adjust the column width of the e-mails section? So, an auto-adjust function regarding the max. width of the column.
Now some of the presented data is truncated and not properly readable. I know that there is an option to hover over the truncated data and then the complete content is shown, but I would like to be able to copy, for example, an e-mail address which is shown truncated. If I select it with the mouse, only the shown data is selected and not the part that is truncated.
Overview adjustable on wider screens
- TrustFire
Re: Overview adjustable on wider screens
The column width of any of the Headers can be adjusted just as usual once you enable the Column Headers:—
Navigate to Display Options >>----> (tick/check) Show column headers.
You can then disable the Column Headers once you are done (if you wish to.)
ps:—
ps:—
- These instructions are valid for MailWasher 7 — not sure they are the same on the Enterprise Server edition, though.
- PSchoon
For the server edition they are not the same, so that is why I made the suggestion. The server edition has a web-based interface and is not as adjustable as one would wish it was.
