Polish translation
- Maciek
Re: Polish translation
Send a PM to rusticdog, he is the firetrust rep here and works with the folks doing several other translations. I think he might still be on vacation but should be back soon. Some of the other translators may contact you to let you know what is involved if you are interested.
- racker
- Knowledgeable Kea
To begin with: you'll need at least a basic knowledge of HTML/XML. If you don't: stop here... read no more!
But if you feel brave: read on!
To show you what you're up against, I've attached two files:
Alias.xml is the index file that I've edited to reflect Polish.
LanguagePO.xml is the languagefile to be translated: as an example I've (or rather Google Translate has) done the settings page. Plse note that I dont speak a word of Polish, so this may be all gibberish to you..
Now here's what you should do:
first, goto HELP>>COMMON FILES>>LANGUAGES
rename the file ALIAS.XML you find there to something like "ALIASBACKUP.XML" or similar, so you can restore it if you wish.
Next paste the two files I've attached to your HELP>>COMMON FILES>>LANGUAGES folder and make backups of both files in a safe place.
Shut down and restart MWP and... you can choose Polski as a language.
As you will see, the SETTINGS>>GENERAL>>APPLICATION page is now in Polish (that is: what Google made of it)..
You can now open LanguagePo.XML with a text editor like Notepad and make the necessary changes.
IMPORTANT: Before you proceed, you must know one or two things
Translatable text is often but not ALWAYS between quotes (" ") take good care not to touch the HTML tags. :!
Typing errors may cause MWP to crash or even overwrite your languagePO.xml causing hours of work to vanish in thin air ( btdt ) so backup frequently!!
Any future MWP update will overwrite ALIAS.XML so you need to keep a backup of that file in a safe place. If you don't you'll have to edit that file manually in order to have Polski back in the menu.
To see the changes you've made in LanguagePo.XML you must temporarily chnge the setting to another language and then back to Polski. To see any changes you make in ALIAS.XML you must close down and restart MWP
Play around a bit and brace yourself... you'll probably be spending more hours behind your keyboard than you could imagine... But hey... it's really fun to see the results!
When Rustic Dog returns, he'll probably tell you more, but in the mean time: if you want some advise, feel free to ask!
As I've done the latest Dutch translation, I think I can give you a hint on where to start...Maciek wrote:Can I expect the Polish translation? Maybe I could help?
- Alias.xml
- (1.47 KiB) Downloaded 342 times
- LanguagePO.xml
- (106.85 KiB) Downloaded 313 times
Beta tester.. oh well! ..
MWP FAQ
MWP FAQ
- Maciek
Racker,
thank you for your help! All is clear at the moment. I start to work. We'll see...
- racker
- Knowledgeable Kea
OK... success. And have fun!
Ohh and to use the only Polish (I think) word I know: Nazdrovje!
MWP FAQ
MWP FAQ
- racker
- Knowledgeable Kea
I see I omittes one thing: if, after a MWP update anything translatable changes in the program, MWP wil automagically add "<translated = false> " to any line in your languagefile that needs (re-) translating. After working on that, you can simply change "false" in "true" for each translated line so the program "knows" you've done your job...
MWP FAQ
MWP FAQ
- Maciek
We're always keen to get more languages added, so you're more than welcome to have a crack.
I see Racker has given you a good amount of information, perhaps one of the only things I would add would be to use Notepad++ as that's a much better text/XML editor.
http://notepad-plus-plus.org/
If you have any problems or questions please feel free to ask here on the forums or you can email me at forum@firetrust.com as well
Chris
Hi MaciejMaciek wrote:Can I expect the Polish translation? Maybe I could help?
Chris
- Maciek
I still work on translation, but I see, I'll need a lot of time :-) I hope, I'll make it.
- racker
- Knowledgeable Kea
Just thought of one more reason to backup really very frequently: As soon as FT will include Polski in a future release, updating to this release will overwrite the languagePO.xml, present in your languages folder. Thus overwriting your working copy and destroying all changes you made since uploading the previous version.
My solution: I have a added a "working file" file called languageNL1.xml and edited alias.xml to load this as the dutch languagefile (added the line <Alias Filename="LanguageNL1.xml" Display="Nederlands (ontw)" /> ). Thus, whenever there's an update, my working file will not be overwritten..
You could do the same by adding <Alias File-name ="LanguagePO1.xml" Display="Polski (work)" /> to alias.xml and rename your working-copy accordingly: to LanguagePO1.xml
I diod tell you, it's a lot of work, didn't I??Maciek wrote:I still work on translation, but I see, I'll need a lot of time :-) I hope, I'll make it.
MWP FAQ
MWP FAQ
Maciek, just a heads up. We're releasing a version of MailWasher later (tonight?), this version has a Polish language file included that's all English text. So just be aware when you install the update to version 1.7.0 your LanguagePO.xml will be overwritten, I say this just to be sure you have a backup as racker mentions
After install you'll also need to edit/update the Alias.xml as well as per the above, so that the Polish language is available in the drop down list.
The reason we've included this dummy language file is that it ought to allow us to release patch versions of MailWasher in the near future rather than full installs. It's a complicated boring reason, but it just means each time we add new languages we must release updates that require a full reinstall, so we've tried to pre-empt your Polish translation by adding this now.
- Maciek
There are no changes in language files in the new version and I can still work on my old file? I mean, if something new is added for example.
I suggest to change file name LanguagePO.xml to LanguagePL.xml. PL means Poland, and PO means Portugal :-)
Bookmark this for the future, it has the most recently assigned codes:
Main: http://www.iso.org/iso/iso_3166_code_lists
HTML List: http://www.iso.org/iso/country_codes/is ... ements.htm
The P section:
The P section:
Code: Select all
PAKISTAN PAKISTAN PK
PALAU PALAOS PW
PALESTINIAN TERRITORY, OCCUPIED PALESTINIEN OCCUPÉ, TERRITOIRE PS
PANAMA PANAMA PA
PAPUA NEW GUINEA PAPOUASIE-NOUVELLE-GUINÉE PG
PARAGUAY PARAGUAY PY
PERU PÉROU PE
PHILIPPINES PHILIPPINES PH
PITCAIRN PITCAIRN PN
POLAND POLOGNE PL
PORTUGAL PORTUGAL PT
PUERTO RICO PORTO RICO PR
Ah bugger, I really should have checked that....PO just felt correct. We can change it easy enough.
As for the changes in the language file, if there is some text that MailWasher wants to display that is not found in the language file, then MailWasher will add the default english text to the file and also with the appropriate Translated="False" tag. It means though the text to be translated though will not appear in the file until MailWasher has tried to display it.
Oh, and to answer your other question. Just make sure you have a backup of your language file, then install the new MailWasher, then replace the LanguagePO.xml with your backup.
