I'm running MWP on Windows Server 2003. If I RDP to the server I'm greeted by the following well-known error message and Application Event Log entries:
Unlike other threads where this error appears, in my case there's no problem with database corruption and the application running locally on the server continues to work perfectly well. I guess the errors are caused by MWP (being in my Startup folder) trying to start a second instance of the application when I RDP to the server. A simple workaround for me is to RDP directly to the console instead which works just fine. However I wonder if the errors in this particular case might possibly be handled a little more gracefully so they're not invoked when initiating a normal RDP session?
