Licence activation problems
- the ronin
Having tried several times to manually enter the licence key into the common files folder (listed under Help) as I had been unable to activate my trial version I found that opening the key file listed in the common files folder of Mailwasher and then clicking Properties in the dropdown gave access by clicking on the Advanced button to another setting (the Unblock). By clicking on this and then exiting the Common files folder following a reboot of the PC the licence key was activated within the Mailwasher app. This worked on both Vista and W7 with which I had been having a problem. The original problem had been that the registration box in the dropdown of the Help setting would not accept the licence key after purchase, hope this helps .Also I had found that on first examining the common files folder in Mailwasher (under help) that the key file was missing, I simply dragged and dropped the keyfile from the email attachment sent from Firetrust after purchase. Byeee
