Mailwasher Pro and Win 10...
hans peter
Fri Jul 31, 2015 2:59 am
Does Mailwasher Pro 7 work with Windows 10?
/hans peter
MW Pro 7.7.0, WIN 8.1
Re: Mailwasher Pro and Win 10...
Fri Jul 31, 2015 6:54 am
I know of two of our Beta testers using W10 before the formal release date.
jpeckinp
Fri Jul 31, 2015 5:03 pm
Been using 7.5 on Windows 10 for a few months and it works fine for me.
Fri Jul 31, 2015 5:04 pm
Yeah we're not aware of any Win10 issues at all :D
umarizal
Tue Aug 04, 2015 12:49 pm
I'm using the final release of Windows 10 Home 64-bit and Mailwasher is running smoothly except for one thing: When minimize it, he should stay only as an icon in the systray, however, keeps appearing in the taskbar like any other program minimized.
Guia da Obra - Forum of construction;
Construção Civil Business - Online catalog of companies and construction professionals;
Comprar e Vender Imóveis - Free real estate classifieds.
Terraplenagem.Net - Portal about Earthwork and Heavy Machinery.
Tue Aug 04, 2015 1:38 pm
Under Settings >> General >> Application >> is MailWasher set to minimise to the System Tray or Taskbar ?
umarizal
Wed Aug 05, 2015 12:10 am
rusticdog wrote:Under Settings >> General >> Application >> is MailWasher set to minimise to the System Tray or Taskbar ?
:oops: Sorry, please forgive me, was it even lacked properly define where it should go when minimized. :facepalm
Thank you! :D
dsiss
Fri Aug 07, 2015 6:51 pm
I've installed Win10 and all seemed perfect with Mailwasher Pro, but now when I launch it and it tells me (in the bottom left of the window) that it's found several incoming e-mails on the server, it only brings one of them into the Mailwasher inbox. I have to press the check mail button again to see the next e-mail as well, again to see the third one too, and so on. I used to get them all in the inbox together with the first check. Is this a setting that I have changed by mistake, or is it something in Win10?
Fri Aug 07, 2015 6:52 pm
dsiss wrote:I've installed Win10 and all seemed perfect with Mailwasher Pro, but now when I launch it and it tells me (in the bottom left of the window) that it's found several incoming e-mails on the server, it only brings one of them into the Mailwasher inbox. I have to press the check mail button again to see the next e-mail as well, again to see the third one too, and so on. I used to get them all in the inbox together with the first check. Is this a setting that I have changed by mistake, or is it something in Win10?
Under Settings >> Accounts >> Incoming Mail >> click Advanced >> disable PIPELINING for incoming/downloading mail here, that should help
dsiss
Fri Aug 07, 2015 7:08 pm
Thank you, rusticdog for a very speedy reply. That has cured the problem - back to operating perfectly again now!
