Hi, I renewed my MWPro last week , received a receipt for the renewal.
As it was a renewal the directions said that I did not have anything to do...Great...A week later (today) when I start MSPro 7 I get a massage to saying i need to Activate the account.
I tried this using the Activation key but it was rejected saying " Unknown Error during Activation, Try again in 5 Minutes" I have been trying for 3 hours.
I sent a Support Ticket and got a response telling me to delete the Key.file and to restart MWPro and register again.
I tied this and I still a the same error "Unknown error ...try again in 5 minutes".
I contacted Firetrust support but am still waiting in a response.
Does any one have any suggestions???
Activation key not working
Re: Activation key not working
I've emailed you your key.file, if you place this into the folder that opens under Help >> Common Files >> restart MailWasher.
That'll get the current license working at least. It sounds like MailWasher cannot access the registration server, but it's a standard HTTP connection on port 80, so I'm struggling to understand what might cause that.
- hktiger
In the mean time I've emailed you your key.file as well.
Odd. Maybe one of our registration servers is playing up.hktiger wrote:I have the same problem at present.
- nick.bolton
- The Big Cheese
Can you guys ping native.first-alert.net and let us know what IP address it comes back with.
eg. Go to Start>>Run, type cmd.exe and that will bring up the Command Prompt window. Type in the window ping native.first-alert.net
It will be either 209.213.221.161 , 209.213.221.163 or 209.213.221.164
Also, can you check your antivirus programs are not blocking this activation link, I had a user last week with Vipre antivirus and it was blocking the link so the user couldn't activate until he allowed it (or I think we temporarily disabled Vipre antivirus to do it)
- parishef
same here I buy and pay for and it registered now it is not working?
- parishef
in fact just deleted the key.file and now nothing but yet it is pinging your servers?
- nick.bolton
- The Big Cheese
Please try this.
Go to MailWasher>>Help>>Common Files. This will open a folder.
Close Mailwasher by going to File>>Exit (this is important to do it this way - don't just minimize Mailwasher).
Delete the file in the open folder called key.file
Restart Mailwasher. Enter your registration key and it should register
- srratcliffe
Hi!
Can you please clear my activation's? I had an incident and had to start anew. And I want my spam world to be back to normal! Thank you in advance!!!
Shawn Ratcliffe
Shawn Ratcliffe
- Sidewinder
- Weary Womble
support@firetrust.com
Contact support at this address. Be sure that your email address is the same one that you used to register:srratcliffe wrote:Hi!
Shawn Ratcliffe
