MWP 7.6.0 download - 20.68Mb wrong file size
Rahosi
Mon Sep 28, 2015 9:52 pm
Title says it all. Repeatedly tried. Same each time.
Re: MWP 7.6.0 download - 20.68Mb wrong file size
Mon Sep 28, 2015 9:58 pm
Odd, working fine on all the test machines I ran it on. Possibly there's bad cached copy, or the download isn't completing properly.
Here's the direct link in the meantime anyway http://cdn.firetrust.com/downloads/mail ... 092015.exe
Mon Sep 28, 2015 10:22 pm
Check out the corresponding file hashes:—
Code: Select all
CRC32
a433c7d5
MD5
9b39aea6c343f4015f54308d9d9f2c5f
SHA1
4b36c43f4a33adeea91ee4884b13284c2e8c52bb
SHA-256
93822885fd0d8c1fc0d74ff1c7582bf7356e4aacc9980b018b91f5e2c68ea0ad
SHA-384
0246f70d5744d96a601d640c89c32f6da74a7a3066f0f2a383d92d0853092fcb379baa16085b86b252a5d8c214483db4
SHA-512
d52749e0fffc75104e3219e0a381fcc608984fc32dba6fe3077ed08f14c0350736e2d04999a5c23934ecf378df9f6c83b549f63f60877642d25169fd155aea7d
Rahosi
Tue Sep 29, 2015 1:19 am
File hash from your direct download link checks out OK, but am still getting the 'wrong file size error' if I try to download using Help > check for updates.
Shame MWP still doesn't work properly with Ultramon. Every time I reboot / start, its on my 'wrong' monitor.
As reported elsewhere
This new Gmail OAUTH security is a nightmare. (3 Gmail Accounts)
Some messages about a wrong token (now disappeared) & about me using an obsolete browser. (untrue)
Messages disappear when MW starts a new check before they can be read and acted upon. The Gmail security checking issues then mix up the credentials of the numerous Gmail accounts that require the additional security checks.
I am not using HideAway. Am using same computer on same broadband connection as I have for years.
Tue Sep 29, 2015 1:46 am
Just check when entering your details that it matches the account. We try to mention the account name twice in the popup, and you can add more accounts via the Add Account button shown in this image.
Tue Sep 29, 2015 2:10 am
Rahosi wrote:Title says it all. Repeatedly tried. Same each time.
Make sure that your security software is messing with the download. Norton and others will block access.
Rahosi
Tue Sep 29, 2015 3:26 am
Can't check the Help > 'Check for updates' link for wrong file size now as have updated.
FYI am using Avast Free & Malwarebytes Home Premium on W7x64U.
AFAIK all software up to date.
Not had any other downloads interfered with by my security settings
The pop-up kept changing as it was checking 3 Gmail Accounts & started mixing up the password requests with the wrong Gmail A/c names as MWP cycled mail checks before completing verification requests. All seems sorted now though.
There were definite references to obsolete software on some of the pop-ups, but didn't have time to go through it all before another check was instigated. Checking needs to be suspended during that procedure.
Tue Sep 29, 2015 3:27 am
Can I ask what version Internet Explorer you have installed ?
Rahosi
Tue Sep 29, 2015 5:06 am
Version: 11.0.9600.18015
Update Versions: 11.0.23 (KB3087038)
[My principle browser is FireFox 41.0 , but I also use Chrome 45.0.2454.101 m (64-bit)]
