Can Mailwasher be used in conjunction with Pegasus Mail, please ??
I tried to do it but comes up with add accounts messages ???
Works Ok without MW but that defeats the purpose
MargM
Linking MW to Pegasus mail ?
Re: Linking MW to Pegasus mail ?
Hi there
So when MailWasher launches Pegasus Mail, it opens but asks to create an account, as though it's not detecting your existing account(s) you've already setup ?
- MargM
Pegasus works Ok without Mailwasher. But thats no good. Under MW settings > washing mail > I chose Mail for Windows as Pegasus not listed. Maybe thats incorrect ?
Bye
MargM
Bye
MargM
Right. So yes, you want to change that.
If Pegasus Mail isn't showing in the drop down list, then instead select the option 'Use Other Application' >> and manually browse for the location of the Pegasus Mail program. If you have a desktop shortcut for Pegasus Mail, you can browse for that and set MailWasher to use that shortcut, then it ought to work as expected.
- davews
I have no problem linking Pegasus to MW, I have done so for many years. I can't remember if it was listed at the time or whether I had to do anything special but I have it selected as 'use other application' and a big Pegasus icon on the tool bar. In fact I never use the 'Start Mail' button or automatically open it after washing, it is just as easy to open it manually myself which I do out of habit.
- MargM
