How to export Blacklist from MWP7
bobsuhaili
Wed Sep 07, 2016 2:02 pm
Hi, I've been using MailWasherPr 7.8.10 for a few weeks now and its pretty good so far.
I have a list of blacklisted emails and domains on the program which I like to export to a text file. The program does not have a feature to do this and I can't find any text file in the program folder either (hidden?)
Is there any way I can export the blacklist without having to manually copy each line? Thanks
Re: How to export Blacklist from MWP7
Wed Sep 07, 2016 2:09 pm
Not an easy way no. MailWasher stores the blacklist in an SQLite database file and whilst that can be extracted, it also would export the regular expression formatting MailWasher uses which isn't really suitable.
Under Help >> User Files >> cache >> if you email me your mwp.db3 file located here to [email protected] >> I'll be happy to send you back a text file of just your blacklist.
bobsuhaili
Wed Sep 07, 2016 3:11 pm
Thank you very much, clean Blacklist received. Great service btw. :)
Wed Sep 07, 2016 3:12 pm
No problems at all.
rd
Luciana
Wed Nov 23, 2016 1:46 am
rusticdog wrote:No problems at all.
rd
Hello!
I read your posts at the MailWascher Forum, and I saw, that you helped somebody to export the blacklist file. I tried very many timest o export my DB3 file, but I couldnt did it right. In sent you my file, could you please convert it and send me the converted file?
I would be very very happy. Thanks a lot.
Regards, Luciana
Wed Nov 23, 2016 2:02 am
Just sent it back to you now.
rd
muncy717
Re: How to export Blacklist (and other lists) from MWP7
Mon Jul 03, 2017 2:36 pm
If rusticdog or other moderator/monk would please confirm, but for others who would like the general purpose capability to browse and export the various MWP7 lists for more advanced editing and importing, I would suggest "DB Browser for SQLite" at the following link: http://sqlitebrowser.org/
This is a great app, and even comes in a PortableApps version. This and either Excel or LibreOffice Calc will provide all the functionality you need to inspect, extract, edit, transcribe and re-import lists from-to MWP7.
AjTeX
Mon Sep 30, 2024 1:56 am
Thank You for the sqlitebrowser link as it helped me to export my blacklist and friendlist as an .csv file and to use for future imports in MW.
