Lost Password
grover7
Lost Password
Sat Feb 18, 2017 2:41 pm
Hi all. I have forgotten my password for Mailwasher Pro, subsequently I cannot get to view my emails on Outlook. Any ideas how i can find it or change it. I`m using Windows 10 and Outlook 2010. Whatever password I try it just comes up with, cannot log in to server.
Cheers in advane.
Re: Lost Password
Sat Feb 18, 2017 3:32 pm
Hi there
Try running the attached. In the ZIP file is show_pass.exe >> run this hit the Refresh button >> it should display your passwords as they've been setup in the email programs.
password.zip
(465.88 KiB) Downloaded 318 times
grover7
Re: Lost Password
Sat Feb 18, 2017 11:00 pm
It won`t let me run it, this is what comes up on screen.
The programme can`t start because accexp.dll is missing from your computer. Try reinstalling the programme to fix this problem
Re: Lost Password
Sat Feb 18, 2017 11:18 pm
OK, that DLL file is included in the ZIP. So maybe save/extract the ZIP file to your desktop first.
grover7
Re: Lost Password
Sun Feb 19, 2017 1:09 am
I`ve managed to extract it and it shows the password but when i put in the password it states cannot connect to the server. When i check my mail in Mailwasher Pro, it comes up with an error in the event log, "failed to log into Pop 3 server".
Re: Lost Password
Sun Feb 19, 2017 3:41 am
grover7 wrote:I`ve managed to extract it and it shows the password but when i put in the password it states cannot connect to the server. When i check my mail in Mailwasher Pro, it comes up with an error in the event log, "failed to log into Pop 3 server".
While there might well be other reasons for the login failure — both the passwords (MWP and Outlook) need to match the password (and Username,) originally used on your web server.
grover7 wrote:Hi all. I have forgotten my password for Mailwasher Pro, subsequently I cannot get to view my emails on Outlook.
The MWP password has no bearing on whether mails would be able to be viewed on Outlook, or not — MWP and Outlook ping, authenticate & handshake with the web server independently.
Ron Lewis
Re:My incoming mail does not display in MWP.
Tue Oct 23, 2018 12:46 pm
i can view it when I go to outlook. MPW says failed to log in to Pop 3 Server. I have had problems with remembering passwords, so I deleted MWP & reinstalled it.
