I decided I wanted to remove MWP and install MW Free instead. I have uninstalled MWP about 4 times now and installed the Free version but when I start it up it keeps starting as MW Pro.
How can I get round this as it is pretty frustrating! After each uninstall I checked the original folder and the only file that show is the 'key' file.
I don't want to use Revo Uninstaller in case it zaps all my settings which I will need for when I get Free version working.
Thanks.
Want to uninstall MWP 7.11
- TrustFire
Re: Want to uninstall MWP 7.11
- Backup "C:\Users\YourProfileName\AppData\Roaming\Firetrust" to a different partition/drive
- Uninstall MailWasher Pro
- Delete the "C:\ProgramData\Firetrust\MailWasher\key.file"
- Install MailWasher Free
- Copy the backup to its original destination, only if required.
- bertie11
