Hi, do you also experience the loss of your login information / re-login required. When you switch wireless / mobile networks when using the APP? Many times re-entering the username and password (which cannot be remembered)?
Also when the network or server side is down like now (Sunday 09:42 Amsterdam time 17 sep) not error message just re-enter login and is does not even work.
When is this app going to be improved/designed by a PRO? if you call this the PRO version?
Dennis D
Change of WIFI / Mobile wireless network, login info lost
- Doffie
- TrustFire
Re: Change of WIFI / Mobile wireless network, login info lost
No — never . . . . . . . ever.Doffie wrote:Hi, do you also experience the loss of your login information / re-login required.
