Hi all, been using Mailwasher for years, but not needed help before.
In the older version, I could see the blacklist in 'user files', but since the update I can't see it anymore.
I back up the folder every so often just in case of a crash, which happened last week. Formattted the disk and in process of re-installing everything.
I copied the back-up filed into the same directory I copied them from, in hope my blacklist would be the but no!!
So, which file holds my blacklist please.
Regards
Computer crash!
Re: Computer crash!
Under Help >> User Files >> cache >> the file that stores the blacklist, friends list is MWP.db3
