Manuals for Mailwasher settings with Gmail and Yahoomail
charlieboy
Mon Oct 16, 2017 5:17 am
Here are some manuals that I have made for Mailwasher users. Go
check them out. :)
Yahoomail:
https://kodebug.weebly.com/mailwasher-w ... omail.html
Gmail:
https://kodebug.weebly.com/mailwasher-with-gmail.html
Send feedback if there is something wrong with the settings.
- charlieboy
Helvetica
Re: Manuals for Mailwasher settings for Gmail and Yahoomail
Mon Oct 16, 2017 3:14 pm
Just one little error, under the POP outgoing settings you have "Next click on Outgoing and enter data seen below.
SMTP server address: smtp.mail.yahoo.com
Server Port Number: 465"
but the image shows the gmail smtp address.
I wouldn't dismiss pop3 as outdated. For many email providers it's handy because it can automatically delete emails from the server once you have downloaded them to your PC. For the permantly hacker-prone yahoo, bt-internet (uses yahoo mail servers) and hotmail, this can be an important security measure.
charlieboy
Re: Manuals for Mailwasher settings with Gmail and Yahoomail
Tue Oct 17, 2017 2:40 am
thank you for reply,
the manual has been updated.
I dont know much about the (technical) difference between IMAP and POP3.
So if someone wants, you can put reply below this message.
- charlieboy
Tue Oct 17, 2017 4:05 am
charlieboy wrote:Send feedback if there is something wrong with the settings.
- charlieboy
charlieboy wrote:I dont know much about the (technical) difference between IMAP and POP3.
- charlieboy
Heads-up:— You can try searching the forum for such trivia — plenty of graphic illustrations are available.
charlieboy
Mon Mar 05, 2018 7:42 am
Manual has been updated.
+ Browsing Mailwasher database file
+ Exporting blacklisted mail data to a textfile
+ Bulk IP Source lookup
- charlieboy
charlieboy
Tue Mar 19, 2019 8:20 am
+ Sending group of IP's to AbuseIPDB using CSV format
- Please send here info for possible bugs, etc.
- charlieboy
enticer
Sat Dec 05, 2020 3:09 am
Tried everything every which way and still cannot get yahoo to work :(
ataraxy
Sat Dec 05, 2020 10:19 pm
enticer wrote:Tried everything every which way and still cannot get yahoo to work :(
The best way that I have found to use Yahoo! is to set up an app password for MailWasher - see https://au.help.yahoo.com/kb/account/ge ... 15241.html
I'm not sure if it makes any difference, but I also use IMAP rather than POP3.
Windows 10
enticer
Sun Dec 06, 2020 12:10 am
Thank you, I'll give this a try. I am setup as IMAP ;)
