I saw this options when using the install wizard but cannot find them now? Can you help please? I believe I also saw the option to stop your client from auto checking mail. This cannot be done with Gmail that I can see.
Is there a way to stay signed into Google and not be signed into Gmail?
Thanks so much! Jack ":-Dx
Turn off/on Leave Message on Server.
Re: Turn off/on Leave Message on Server.
Hi Jack
Do you use a specific email program or just use the website for your GMail ?
- jackdashack
I use Gmail website in a browser. Thanks I hope that's enough info. Appreciate you taking the time. ":-Dxrusticdog wrote:Hi Jack
OK, that's fine then, you don't need to disable any option for that. And using GMail in the browser doesn't have an auto-check feature that you need to be bothered about either, when you go to the website it will load your emails, and doesn't have any impact on MailWashers operation.
- jackdashack
Did not see right off a SOLVED or KUDOS but thanks greatly for your time and if there is a solved or such please inform me. Thanks. (new here) jack ":-Dxrusticdog wrote:OK, that's fine then, you don't need to disable any option for that. And using GMail in the browser doesn't have an auto-check feature that you need to be bothered about either, when you go to the website it will load your emails, and doesn't have any impact on MailWashers operation.
- jackdashack
Also one last. When I click on MAIL PROGRAM is does nothing. Is that because it's a web based email? Thanks!jackdashack wrote:Did not see right off a SOLVED or KUDOS but thanks greatly for your time and if there is a solved or such please inform me. Thanks. (new here) jack ":-Dxrusticdog wrote:OK, that's fine then, you don't need to disable any option for that. And using GMail in the browser doesn't have an auto-check feature that you need to be bothered about either, when you go to the website it will load your emails, and doesn't have any impact on MailWashers operation.
Yes. As you won't have a mail program setup.
If you go into Settings >> General >> Washing Mail >> select from the drop down to Use Web Address >> enter in www.gmail.com >> Save. Now when you press Mail Program, it will open up your GMail.
