When I reply to a message in Gmail it's also sending a copy that pops up in Mailwasher. Is that right?
Also, I guess Mailwasher doesn't download attachments?
Thanks, I'm getting on to most of it now by using it. Just these couple of questions I can't seem to find answers to.
Thanks! jack ":-Dx
REPLYING is sending a copy that Mailwasher loads?
- jackdashack
Re: REPLYING is sending a copy that Mailwasher loads?
Hi Jack
I'm not sure why GMail does this, but if I recall you have two options for the Sent emails.
Change MailWasher to use IMAP, you can do this under Settings >> Accounts >> Incoming >> change the Server Type at the top. Small note about IMAP, MailWasher loads all emails in the Inbox that are Unread, so when you read an email in GMail, delete it, or move it to another folder, MailWasher will no longer load it.
Or create a filter in GMail. If you click the Settings icon at the top right >> select Settings in the drop down menu >> click the Filters and Blocked Addresses tab >> click Create a new Filter >> enter your GMail address in the top FROM field >> click Create filter with this search (bottom right) >> select the top option Skip the Inbox >> click Create Filter
- jackdashack
Thank you very much. I will follow this plan. Jack ":-Dxrusticdog wrote:Hi Jack
