I am needing a way to block top level domains?
CWM030
Sun Dec 24, 2017 2:02 pm
Hello,
My mom gets alot of junk emails as you see by the image attached from domains like .win .xyz .im, .fr, .ru etc...
https://imgur.com/a/0v9lc
How about ones like these in this picture? ( Sometimes they dont come in as .xyz) just MX(number)...... https://imgur.com/a/blVor
I am needing to know is there a way to block those top level domains and that MX crap.
Thank you,
Chris
Thanks and take care,
Chris M.
Chris@CWM030.com
( I know. and am aware that its bad to add your email address to the bottom of your signature .
I dont mind that my email address is out there, So please don't edit it out.... ) Thanks!
:bow :nono
Re: I am needing a way to block top level domains?
Sun Dec 24, 2017 2:08 pm
So assuming no legitimate email is received on these TLDs. The quickest way would be to add some entries to the Blacklist as wildcard expressions. You'll want to add them manually and be sure wildcard expression is selected when adding.
For example to catch those in your first screenshot...
*@*.im
*@*.biz
*@*.ro
To catch all the MX ones you could use
*@mx*
Though that would catch something like emailaddress@mxhelp.com as well, but I'm not sure that's going to be an issue.
CWM030
Sun Dec 24, 2017 2:20 pm
( I cant delete this reply )
Chris M.
Chris@CWM030.com
:bow :nono
CWM030
Sun Dec 24, 2017 2:24 pm
rusticdog wrote:So assuming no legitimate email is received on these TLDs. The quickest way would be to add some entries to the Blacklist as wildcard expressions. You'll want to add them manually and be sure wildcard expression is selected when adding.
*@*.im
*@*.biz
*@*.ro
*@mx*
Thank you so much I added the :
*@*.im
*@*.biz
*@*.ro
*@*.xyz
to her list... I will see if that helps any!
On the MX I dont want to block out any domains that might have like mxdomain.com
Just the afdsasd@mx1.xxx.xxx
The .mx1 .mx2 parts.
Thanks,
Chris
Chris M.
Chris@CWM030.com
:bow :nono
Sun Dec 24, 2017 2:26 pm
OK, the more detailed way would be then to add each, that should ensure less chances for any errors...
e.g.
*@mx0.*
*@mx1.*
*@mx2.*
*@mx3.*
*@mx4.*
*@mx5.*
and so on...
CWM030
Sun Dec 24, 2017 2:31 pm
e.g.
*@mx0.*
*@mx1.*
*@mx2.*
*@mx3.*
*@mx4.*
*@mx5.*
and so on...
Thank you again!
Chris M.
Chris@CWM030.com
:bow :nono
