Handling the filters
vbecto
Fri Feb 23, 2018 9:04 pm
Hello, don't know whether I'm right here or not.
I have several problems when a filter marks a message and deletes it... How can I figure out which word from the respective filter was auspicious??
There comes a message with only 3 lines of text, not html, with 1 att. and with a normal subject...
TIA for your kind reply.
Volker
Re: Handling the filters
Mon Feb 26, 2018 1:45 pm
Hi Volker
Unfortunately there is no easy way to see which rule tags within a filter. It pays to not include too many rules in one filter so you don't have to go through many lines. You can try sending some test messages to yourself with some of the words to narrow it down.
vbecto
Thu Mar 22, 2018 9:45 pm
Thank you, for your kind answer!
Actually this no way; till today I have 10 Lists, wach with approx 100 lines...
Best regards, Volker
