Unable to install MWP
Ticker7
Sat Feb 24, 2018 8:57 pm
Hi I've been using MWP for many years now mostly with little or no trouble, last night I tried to start the program but it didn't start so I did a repair install to try to sort out the problem but when the installer finished I got this error msg. I have since tried to uninstall but get the same error at the end of the uninstall process.
Please can someone help me to resolve this problem.
Error Msg
Setup error.JPG (19.83 KiB) Viewed 2354 times
Re: Unable to install MWP
Sun Feb 25, 2018 2:41 pm
Try uninstalling, keep your data files when prompted >> then reinstall from http://cdn.firetrust.com/downloads/mail ... _11_05.exe
Ticker7
Sun Feb 25, 2018 6:07 pm
Hi Thanks for the reply but I've sorted it. I rolled back the Founders edition of win10 and it's now working again as it should ;-)
